    Dismiss Notice
What would happen if you used Zinsser Bin and a water leak reocurred?
Discussion in 'Decorating and Painting' started by dijc, 16 Nov 2018.
  1. dijc
    dijc
    20 Dec 2016
    20
    Thanks Received:
    Country:
    Or any stain blocker/oil-based undercoat etc
    Would a stain from the water leak simply appear again in the same place?
    Or would the water be "trapped" behind the Zinsser Bin and need to find somewhere else to escape?
  2. Sponsored Links
  3. SwitchTheElectricsOff
    17 Jul 2014
    166
    Thanks Received:
    3
    London
    Country:
    I had this in a property many years ago, the Bin acts as a barrier, so whilst the water will be trapped behind the barrier, it will divert elsewhere, so if you are going to use a barrier, do a reasonable large area so there will be no/minimal leakage
    Has the leak stopped? If so, let the stain come all the way through before you do anything
    • Thanks Thanks x 1
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
