So we're doing quite a bit of work to a 16th Century farmhouse, part of this is to redo the kitchen, I've had the floor boards up in the bedroom above today to start sorting out the wiring and have found some rather worrying looking joists.
My main concern was with this one, as the original electrician decided to drill the bottom of the 4" joist, then when the house was rewired the next electrician decided it would be a good idea to notch the joist directly above the holes!!
This joist is already not the best as it has a fair bit of wood worm, is a little soft on the edges but hard towards the middle.
I then lifted a few more boards to get to some disused cables and found that there was a joist running in the opposite direction, about a metre from the wall, one end of this joist sits on the joist our electrician friend notched, the other end I haven't found yet.
There are then 3 maybe 4 joists that sit between the wall and this joist, so infact the dodgy joist is holding up half the floor!
They've been nicely jointed too, they basically sit on a bit of batten
I then decided to expose more of the dodgy joist so that I could look at putting a new joist alongside and bolts them together, and found this is what the end looks like
So my current thoughts are to put a bit of 4x4 in alongside the dodgy beam, use some joist hangers each end that are large enough to go under both dodgy joist and new joist and then attach them to the main beam one end and the wall the other end.
Then use either some big fat screws or some coach bolts along the length to tie the two together.
And then where the joists run which have a joist running through the middle of them I could put some steel plate on the top of the two joist parts are the one running perpendicular to tie them all together and give it a bit more strength.
Any other ideas?
This is a duplicate thread from the flooring forum but I know it's a lot quieter in there and could really do with the advice quite soon as the plasterer is coming on Thursday.
Ed.
Any other ideas?
Ed.
