Whats best
Status
Not open for further replies.
12 Apr 2005
My kitchen is an old extension which needs the existing concrete floor replacing. What would be best DPM on a bed of sand directly under the screed (40mm sand/cement semi dry) or a DPM coating applied in two coats on the surface of the screed.
Thank you
As I said on your other posting you need a minimum 50mm and preferably a75mm screed if it is un bonded to prevent cracking.
MOD
see item 1a
Status
