Drained system down and flushed it through a couple of weeks ago to replace the cleaner with inhibitor. Filled back up and bleed the system and everything was fine. But I've noticed recently that when hot water is on the boiler sounds like it has air in it as it swirls and gurgles faintly. On CH there is no noise.
When I bleed the system after filling I did open the air lock valve on the top of the pump and also the large screw head on the front.
Any idea what is causing the noise.
