What's the best torch-on felt available?
1 May 2008
London
Hi, im about to re-roof my flat roofed extension, the joists are all fine but im replacing the deck with 18mm WBP,my question is what is the best quality 3 layer torch-on felt on the market as i don't want to re-roof in again for many,MANY years.
The best torch on membranes are Bauder K5K capping sheet (mineral) and Bauder G4E underlayer, lifespan of over 45 years I believe witha 20 year guarantee. Expensive but first class.
Bauder Ltd
Regards,
Correct, Bauder is the ultimate felt....but, not available for public, or non approved installers to purchase, keeps the riff raff from giving it a bad name 8)
If you are going to walk into a roofing stockist, ask for Marley Goldseal. SIG group will hold it. You only need a 2 layer system, unless insulating when you will require an alucored vapour control layer.
You can buy the best felt in the world, but if its not installed correctly, its a waste of money.
I started installing Bauder over 25 years ago, and i've never heard of it failing, Germany have some 40 year old Bauder roofs still going strong.
Hi Xenon, what contractor do you work for ? I worked for Bauder Ltd for many years at their head office.
Their systems have always been top of the range.
Cheers,
Ok, Breyer are their biggest customer !!
Im not convinced on the hot melt type systems. They can be good where awkward detailing is conerned, apart from that I'd stick with torch applied membranes.
