Hi All,
having had several heating systems\rewires etc a lot of the existing timber boards are basically wrecked, I was planning on robbing the boards out of the living room to replace the others around the house and then doing the whole living room in chipboard T&G. Its a 1960 house and its going to be carpeted over.
Ive seen loads of posts on how to correct a poor chipbd floor so how do you do it properly to start with??? (or is it just the devils work and to be avoided
Do you
glue all the joints with PVA
Add talc not PVA to the joints
put 3 or 4 screws per 600mm board
silicone the ends to fill the gaps against the wall
hang the expense and use real wood floor boards
I was also going to add insulation between the joists -seems daft not to with all the boards up -so whats the best option for that?
Any help appreciated
Do you
