    Dismiss Notice
Whats the least back breaking way to lay a patio?
Discussion in 'In the Garden' started by happypeter, 16 Aug 2020.
  1. happypeter
    happypeter
    12 Jul 2019
    123
    Thanks Received:
    4
    Country:
    The last time I used the old 600 X 600 slabs and it almost killed me. Can anyone give any tips as to what method / materials make the job a little easier?
    I've seen porcelain paving described as 'lightweight' but not sure I believe it.
    thanks
  2. Sponsored Links
  3. Tigercubrider
    Tigercubrider
    22 Jul 2016
    4,511
    Thanks Received:
    729
    Country:
    Pay someone else
    • Like Like x 7
  4. mattylad
    mattylad
    27 Apr 2008
    8,168
    Thanks Received:
    619
    Country:
    What ^^^ said.
  5. ETAF
    ETAF
    24 Apr 2008
    1,072
    Thanks Received:
    191
    UK, Wittering, West Sussex
    Country:
    • Thanks Thanks x 1
  6. Annoying, others got in first with the correct answer
  7. happypeter
    happypeter
    12 Jul 2019
    123
    Thanks Received:
    4
    Country:
    This a DIY forum so clearly I've decided against this
    For anyone else finding this thread by searching..
    Vitrified porcelain seems to be the best option. At 20mm thick manufacturers claim they are lighter than traditional slabs.
    Block paving is also far easier to lay although not suitable for my needs
    • Thanks Thanks x 1
  8. Keithmac
    Keithmac
    10 Oct 2017
    2,119
    Thanks Received:
    337
    Country:
    Is lighter always better or will they be easier to crack if something drops on them?.
  9. OwainDIYer
    OwainDIYer
    5 May 2010
    4,545
    Thanks Received:
    695
    Stirlingshire
    Country:
    Two people, and a paving slab lifter. Even better is a vacuum lifter.
    https://www.speedyservices.com/73_5405-h-handyman-vacuum-lifter
    • Thanks Thanks x 1
  10. Sponsored Links
  11. Munroast
    Munroast
    17 Aug 2010
    1,684
    Thanks Received:
    254
    Country:
    I made my own crane
    [​IMG]
    • Like Like x 3
    • Thanks Thanks x 1
  12. happypeter
    happypeter
    12 Jul 2019
    123
    Thanks Received:
    4
    Country:
  13. happypeter
    happypeter
    12 Jul 2019
    123
    Thanks Received:
    4
    Country:
    Thats genius love it!
  14. lonner
    lonner
    14 Jan 2010
    290
    Thanks Received:
    51
    Cambridgeshire
    Country:
    Technique is everything when laying slabs.
    Let the slab take the weight, walk the slab, rocking corner to corner.
    Place slab on edge of laid slab , slab standing up and lower it into place, adjust with trowel or shovel to get gaps correct.
    Repeat
  15. Ian H
    Ian H
    14 Sep 2010
    7,026
    Thanks Received:
    853
    Rochdale
    Country:
    What about the 4 size sandstone? You get a heat 3x2 then a break while you lay the 3 smaller ones.
  16. happypeter
    happypeter
    12 Jul 2019
    123
    Thanks Received:
    4
    Country:
    I do like the look of them and at 20mm thick they can't be too heavy. Any idea of the weight of the larger ones?
    ta
  17. Ian H
    Ian H
    14 Sep 2010
    7,026
    Thanks Received:
    853
    Rochdale
    Country:
    I got a 19mtr pallet and it weighed 1000kg so maybe around 25kg for a 3x2?
Loading...
Share This Page
