Hi there, I know probably loads of questions have been asked about stud partition walls, but......
So far I have found that the advice seems to be to use 100mmx50mm timber and to fix the verticals at 600mm centres between sole and head plate timbers. Then use 100mm insulation to fill the gaps, but what exactly is it called and is it best to use rigid boards or fibre based stuff?
Is it worth double boarding with 12.5mm plaster-board on top of all this? I am quite keen to keep the noise down as much as possible without going mad.
So all in all am I going the right way with this, is there something I'm missing?
Many thanks
Many thanks
