When an electrician changes meter tails...
you change tails for 25mm, chances are the dno cable coming in is only 16mm cu or 25mm al anyway, unless youve had an upgrade
AFAIK, the sticker on the carrier is only to confirm the highest fuse rating the carrier can take.
Although the 60/80 stickers are confusing.
I heard this from a guy that used to work for the DNO.
