Hello everybody!
I have a Grundfos 15/50 in my flat and it stopped working the other day. A friend told me that I could take out the screw in the centre of the pump and play around a little bit with a screwdriver in the hole. This little trick did work, and now I have heating in my flat again.
My question is: is my problem now solved, or should I consider replacing the pump altogether? Presumably, this shouldn't happen (or is this normal?). How long would you guys reckon that I have until the pump completely fails?
Cheers,
Mala
Cheers,
Mala
