- Joined
- 27 Jan 2008
- Messages
- 28,296
- Reaction score
- 3,440
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
My oldest BS7671 is the blue cover 412-06 referred to 30ma and was referenced with 608-13-05 although I will admit it could be easy miss read as also there was a reference to 413-02-18 to 413-02-20 which was no more than 50 volt at 5 seconds. So at the time readers may have considered with a PME supply a 100ma RCD was good enough but with hind sight I realise in June 2001 caravan sites needed 30ma RCD protection.
However when did this come in? Was it before or after the regulations became BS7671?
Also when did the ELCB-v become outlawed? Came across one last year still in use in a farm.
The discussion was about caravans being about the only time where two 30ma RCD's are put one after the other and I said it was belt and braces approach in case site owners had not got around to fitting RCD's of 30ma. One guy said we were allowed 100ma on sites with 16th Edition hence question as reading mine it would be easy to miss read and think you could use a 100ma and only on more careful reading did it become clear it was 30ma.
So now not sure if miss read all those years ago or if pre-2001 100ma could be used?
