Where’s my electricity going!?
Hi.
Right then …! Electricity consumption from 4th June to 4th July 2025 was 173.4 kWh. From 4th June to 4th July 2026 it was 268.83 kWh.
During the first period I was running an electric double oven and induction hob, which I’m not doing at the moment as I’m using gas for cooking. All other appliances are the same for both periods, except I now have an immersion heater which I thought was running for 1 hour per day on Economy 7.
This might be the answer! The “timer” is set to come on between 5:00 and 6:00 every morning. Over the last few days I’ve been switching the immersion off at the isolation switch, and turning it on for a short time when the water temperature in the tap went cool. I’ve not checked the consumption over this period yet. However, it dawned on me that although I turned the power back on last night and the water quickly warmed up, it shouldn’t have done as the timer should have been off. So, timer not working.
Also the water temperature used to be scalding hot and turning the thermostat down had no effect. So, thermostat not working.
I’ve also found in the loft some sort of tv signal booster which is on all the time.
I have a smart meter, but no separate display unit. When I asked Octopus to send one they said that the display wouldn’t work with the current meter as it was an older meter. I asked if they could replace the meter, but apparently they do not do this on a one off job, only as a planned update programme.
I reckon I’ll get a plug in energy monitor, a new thermostat, a new timer and an electrician!
Thanks again for your replies.
PS. Sunray - I was quoted £1,400 for travel insurance (bypass). I took out a Nationwide Flexi Plus account which costs £18 per month. This included free mobile phone and vehicle breakdown insurance as well as Aviva travel insurance. My pre-existing condition premium was an additional £137 and included cruise cover. Saved about £1,000.
Immersion heater first, mine will turn on at the thermostat around once every 3 to 4 hours, it does not stay on for long, the spike is about the same as the electric kettle, once it had warmed up first time in the day, the Octopus app is useless as it only shows in ½ hour blocks, even the solar software old shows spikes 1786178494413.png so can't work out except for first this which is immersion and which is kettle.
It should be at least 60ºC to stop legionaries, which is scalding hot, if it does not switch off with the thermostat, then the cut-out should work, and these need a manual reset, if no cut-out it would boil the water, which you would hear. And the cold water tank would get warm.
268.83 kWh at 32.277p/kWh = £86.77 without the standing charge, around £108 with standing charge. That's less than we paid before fitting solar, so not unreasonable. About £31 more to your last home, so around £1 a day extra or 3 kWh, so last year my immersion heater Last 28 days1.jpg and this year Saved last 28 days Tuesday 4th Aug 26.jpg so I have used a lot more this year, and not a clue why, we do not use hot water fill on washers and driers, or even the shower, only used to wash our hands.
I have an array of plug in energy meters, two only measure, which is what I want for the freezer, don't want it to turn off, but the rest can also switch items on and off, the Tapo (TP-Link) P110
is a multi-function device, and I use it to turn lights, fans, air conditioning, and battery chargers on and off, it says "Hub Not Required" I have the hub, so don't know if that alters what it can do, but find them handy to ensure at least once a day things are turned off, as to if they pay for themselves hard to say, but to turn outside lights on with phone before leaving car, and off in the house with a voice command means well worth it for me. (I have Nest Mini for voice command bit)
The smart meter I find next to useless, even if no solar, to work out what is drawing power is hard, you can get clamp-on meters to measure all, 1786180583568.png1786180625027.pngBut £76 is a lot to pay, it needs the hub, and yes a good display on the computer 1786180774142.pngbetter than the smart meter, one shown is from the plug in monitor, there are cheap ones
not a clue how well they work? But working out what has produced the spikes is near impossible.
But I have moved my plug in energy monitors around, and measure a washing machine, and never the same results twice. It weighs the wash, and alters program to suit.
July 2025
July 2026 and yes my consumption has hardly altered, 2024 422.4 kWh not record any further back.
Sounds like it’s very difficult to measure anything with any certainty. I’ll just see how it goes.
