Where can i get a 160mm oblique wye junction with no sockets
Can you use a clayware junction? I don't think you'll find a plastic version without at least 2 sockets, however the clay 'sleve' type will have 3 x spigots, all joints are made using collars.
Edit, Denso beat me to it!  8)
Excellent thank you, i guess clay will be fine. I have no idea why there so hard to find, thought everyone would sell them. Thanks again!
Most Builders merchants should stock clay drainage, you are unlikely to find it in the sheds. It is quite fragile, do not drop! :lol:
Thanks guys, appreciate it. Any ideas roughly how much a saddle should be? Only one ive seen (online) was loads of money but seems a much easier way of doing it if there not normally that much, thanks
Don't know what you doing, but can't you just slice the pipe to form a channel add a slipper and build an chamber around it
I'd be very wary of trying to fit a saddle, especially onto clay pipe. The chances of getting a clean hole without the entire pipe cracking or breaking are slim IMHO. Use a junction or as doitall suggests, a chamber is even better, as it provides rodding access along the proposed connection.
Or fit a plastic chamber with 160 through channel and 110mm slippers. http://www.pavingexpert.com/drain15.htm
