Where to buy laminate for worktop?
5 Jun 2011
Gloucestershire
Surprised there's no kitchen forum.....
Anyway, when I did the kitchen in our previous house I made all the worktops from 1" blockboard and laminate, made my own edging. That was in 1981.
The kitchen in our current house has a free-standing cooker, which I'm going to replace with a built-in hob & oven, and I need about 4ft of worktop to match what's there. I think the existing top dates back to about 1994.
White, slightly textured, 1" thick.
The worktop in kitchen shops and Homebase is nothing like. I've been looking for laminate to make my own, but no one seems to stock laminate sheet any more.
Any idea where I can get some? I'm near Gloucester.
Alternatively, we could get the whole lot replaced in Corian, pricey, and I've been told it scratches easily. What do we think?
Ivor
Having trailed round all our local builders merchants, Homebase, Wickes - where the staff were amazed to hear that in the olde days we used to make our own worktops - I went into a local hardware shop, Millington & Ramsted, and behind the counter they had Formica's sample chart hanging up, and Yes sir no problem to order a sheet. Four different whites, one of which was just called White, guess they ran short of silly names.
It's a lot thinner than it used to be. Probably a lot easier to cut too.
I'll stick it to 1" blockboard (prime the board with glue first and let it dry) and varnish the edges well to make sure the damp can't get in where it comes up against the end of the sink.
Then make an elm edging for the front.
Be 'fun' fitting it against the wall, straight it ain't. Whoever fitted the existing worktops gave up and used a lot of silicone. I'll make a cardboard pattern, and from that a plywood pattern, and from that I can profile the worktop.
Afterwards I have to make the cutout for the hob and build the ventilated under-structure for the oven. I have an elm door I can take apart to get the wood.
DIY olde-style.
Ivor
DIY olde-style.
Ivor
Sounds ugly
DIY olde-style.
Ivor
Instead of cardboard and then ply to make a template just use some hardboard
Try stantons of weybridge
Thankyou. I used to live in Shepperton (says he, hurriedly editing his Profile), and now you mention the name I think that's where I bought the laminate in 1981. The showroom didn't exist then, as I recall. Amazing to see them still in business. Thankyou.
Next problem, having found some laminate, 1" blockboard has vanished. All I can find is 20mm and even that's not generally available. And, instead of being made of hardwood offcuts, it's made of softwood. Still better than particle board though.
As you as you take your eye off the ball for 32 years, it all changes.
Hmmmph!
Ivor
