which adapter to fix a holesaw on Bosch PBH 2000 SDS drill?
20 Oct 2011
West Lothian
I have a "Bosch PBH 2000 RE SDS Rotary Hammer Dril" (http://www.amazon.co.uk/Bosch-2000-Rotary-Hammer-Drill/dp/B000RW024A/ref=sr_1_1?ie=UTF8&qid=1319127682&sr=8-1)
I need to drill a hole through plaster for the dryer's air; the bit through the brick is already there, there is already a storm protector on the other side. I just need to make the hole inside the house and put a pipe basically.
For the job I suppose I need something like : http://www.toolstop.co.uk/bosch-2608584811-sheet-metal-holesaw-102mm-p9764 (is this for metal though? If so, I suppose it should should work for plaster :) the diameter i need is slighlty over 100mm, so 102mm is good)
now what bit do I need to fix that holesaw on my PBH SDS rotary hammer drill? :)
I can't really find out....
Thanks for helping a diy newbie!
the sheet metal hoesaw as the name suggests is for sheet metal and it has the bosch quick change arbor - and to my knowledge they dont do a sds srbor to fit
just buy teh cheapest crappiest holesaw you can find - cutting plaster will bugger it anyway
