Which bolts..
31 Aug 2005
Just about to build my timber base for 6x5m shed.
The timbers need to be bolted to my upright concrete posts i have cemented into ground (100x100) and the timbers are 7x2.
Im aware i dont want them pulling through.. should i use large washers or are there purpose bolts and washers i use, i guess i should use 2 per post vertical lined?
Was looking at these
http://www.screwfix.com/p/sabrefix-m12-timber-connector-galvanised-dx275-50mm-x-50mm-50-pack/99094
Its more about stopping head pulling through timber im concerned, i see they do some large square washers also.
Provided you will never ever want to undo them, and are happy to use a hacksaw when demolishing, buy some galvanised studding in the largest size that will fit. I think it is M8. Possibly M10. It is quite cheap and easy to fit. Penny washers will do. You can grease and paint it, but it will still rust. You cut the lengths after assembly.
If you ever hope to unscrew it, use stainless. If you are obsessive, use stainless acorn or dome nuts on the outside for their beauty and because they will not scratch you when you brush past. Stainless needs Nickel anti-seize grease.
Large bolts work out more expensive.
p.s.
The round timber connectors with teeth in your link are meant to go between two pieces of wood to prevent rotation on the bolt. They are not what you need and will not work on a concrete post.
With two bolts or studs, the posts will not pivot or rotate.
We bought galvanised nuts bolts etc for a timber framed house in 1980 from Galvanised Bolts and Nuts Ltd in City Road London N1 and they are still in good condition 37 years later including those exposed to the weather. Some were 20 mm diameter.
The company's present registered address is 115 Lodgefield Road, Halesowen, West Midlands, B62 8AX
Generally, it's square washers to stop pull through.
Those spur washers are to join timber to timber to add strength to beams, and won't do anything to stop bolts slipping.
Better still, Google for "Joyner Bolt "
