Which brand lining paper?
3 Nov 2005
Liverpool
Looking for a paste the wall standard lining paper.
Its a toss between ErfurtMav paste the wall or Albany paste the wall which i am told is Wallpaperdirects own brand.
Is any better of quality.
I've never used 'paste the wall' lining paper before. I always use a lining paper that requires the paste to be applied to the paper.
I have used many brands including the local DIY shed's own brands. They all seem to do the job.
The most important factor to consider when choosing will be the grade of lining paper and this will be dependant on the condition of your walls.
I too have only used paste the paper lining paper and tend to use dulux (ICI) due stockist being easily accessible due to location. Never had any problems with it either! That said I have used other brands of lining paper and all seem to do the same job.
As RMS says picking the correct grade for your walls is a good idea, i,e the better the walls the lower the grade you will need!
Forgot to mention make sure you paste the right side, Sounds simple but I have found using different types that they can be rolled the opposite way. Feel both sides and paste the roughest side as you want the smoothest side for your paint finish!
