Hi all,
My sister just had a single rear extension done. It's an end of terrace. Ground floor rear extension. This has resulted in adding to the current central heating system 3 new radiators i.e. a Towel rad in the new toilet, a 40cm rad and a 45cm tall vertical column rad in the extension
Builder in their infinite wisdom did not test the heating till all building work has been completed and now say the lack of heating to the furthest 2 radiators in the extension (i.e 40cm rad and the vertical rad) is boiler issue which I think is wrong.
All existing Rads gets piping hot so no obvious signs of sludge. I have tried balancing by shutting off a couple of existing rads to see if the heat will get to the last 2 rads but they just gets Luke warm and then back to cold.
Boiler is a Baxi conventional and relatively new. Pump is Grundfos UPS 15-50 (130) ... but does make a fair bit of noise, possibly cuts on and off so I am thinking this might be the issue.
So radiators in the house are:-
1st floor : 3 rads and 1 towel rad rad
ground floor : 2 * 180cm rads, 1 * 40cm rad, 1 towel rad, 1 * 45cm (wide) tall vertical column rad
My question is do I buy the Grundfos UPS3 15-50/65 (£115) or a more powerful pump? If I need one with more power which one?
