Which finish for skimming?
16 Feb 2006
Sussex
What type of thistle would you recommend for skimming over an artexed bathroom ceiling. Board or Multi finish?
The artex is not a deep heavy pattern, its the light "pimple" effect (circa 1970's)
you could use either, though i would say multi gives the longer working time.
i prefer board finish for its swift predictable curing rate.
Fortunately the area is only 6' x 6'.
Its one of those jobs i want to have a go at myself.
Worse case scenario, if i balls it up, i'll cut my losses and re-board.
If the finish is a bit iffy after you've plastered you can always use jointing compound to fill small dips. the great thing about jointing compound is it can be easily sanded when dry. good luck
I have alo used SmoothOver to good effect when having had a go at plastering. Purists will scoff, I am sure, but, with its big spreader-thingy, it does a good job of covering the mistakes! As far as i can tell its just a fine polyfilla-type material.
I'm not sure but I think smooth over is jointing compound re-packaged for the DIY market. and with a re-packaged price of course :wink:
I had a go at skimming a wall last week. The results weren't too bad but had a couple of issues.
The old coat had blown so I scraped the whole lot back to the render. I then did 3 coats, hardwall, browning and multifinish. What I found is that when I came to apply the finish coat and polish it, it sometimes came off in patches. Not a big deal and I was able to fill in the holes.
The main prob was the pits and grooves which I hadn't polished out. My feeling is that its down to my lack of experience. I had the multifinish mixed pretty sloppy, but it still only gave around a minute of working time on the trowel.
Did you let the browning dry before applying finish? If not, did you PVA the browning before applying finish?
If not - that'll probably be why the finish went off so quickly. If you did PVA it all then maybe the plaster was old. The older it gets the quicker it goes off.
If it's a first effort then well done. You're right - it's experience and know how. Keep practicing and you'll get better and better.
Fred.
