Which levelling compound on damp porch floor?
4 Sep 2009
Worcestershire, UK
I had originally thought of using self levelling compound over the tiles in our porch, but they were so far out I decided to take them up yesterday. The base is a bit damp so I need to find a self levelling compound suitable for using in this situation. The porch is 1.5m x 2.5m and was built in the 80s.
Ardit NA and F-Ball 1200 can both be laid over damp subfloors as they are moisture tolerant, however, what do you plan to fit over the top?
Thank you, I'll see if I can get some. I was thinking of Karndean rigid core flooring as I have enough to do that area, but may get ceramic or porcelain floor tiles if that would be a better option.
If it’s damp I’d put na / 1200 pro then go with a liquid Dpm like ardex DPM1c or fball F77
Porcelin/Cermic will just need levelling and fit.
Kandean Rigid Core or any other Click or Glue LVT will need:
1 coat of Ardit NA or 1200 Screed Coat
1 coat of Ardit DP-C or F-Ball F77 Liquid Dpm
1 Final screed coat of Ardit NA or F-Ball 1200 or a screed of your choice with appropriate Primer.
This prep is very important.
