I got the choice of a Worster bosch 30si or a 30cdi. I got 11 radiators over a four bedroom house and one bathroom, but hopefully put an on-suite in a bedroom. Will the 30si be ok??
Thanks, Banjo13.
Go for the CDI much better boiler difference in price is a shade over £195 however if you employ a WB approved installer your warranty period will be a minimum of three years with an option to purchase a further two for an addtional £115 or you might get the five year warranty for the same price as the boiler, depending on the AI.
The 30 indicates the power, hence both models are similar in that respect.
As mentioned above, the cdi is a markedly better boiler; as the price difference is only a few percent, it should be a no-brainer.
