    Dismiss Notice
Which paint?
Discussion in 'Decorating and Painting' started by nabby68, 16 Nov 2018.
  1. nabby68
    nabby68
    30 Jun 2005
    653
    Thanks Received:
    Country:
    Hi
    We had a kitchen and utility extension built 12 months ago and for speed and convenience I painted all the bare plaster on walls and ceiling with Leyland Trade Matt Emulsion. So now I’m thinking I maybe need something more hard wearing as there are some light scuffs on the walls and the external corners some of the paint has come away. Not sure about using Eggshell as I like the Matt finish. Any advice appreciated
  2. opps
    opps
    16 Jun 2006
    5,166
    Thanks Received:
    817
    London
    Country:
    Hi Nabby
    Have a look at the likes of Dulux Trade Diamond matt. It is about £45 per 5L (white).
    https://www.duluxdecoratorcentre.co.uk/dulux-trade-diamond-matt
    At a push you can scrub it with a green scouring pad but if you are too aggressive it may make the area slightly shinier.
    You may find the first coat seems thick as it soaks in to the existing emulsion. Try to avoid over rolling the first coat otherwise you may end up with a finish that feels like someone has added very fine sand. The second coat should slide more easily.
    The second coat does take a bit longer to dry than standard matt but you should be able to apply two coats in one day.
    I normally spot prime any bare plaster with thinned standard matt emulsion to provide a uniform "canvas".
    • Like Like x 1
  3. Sponsored Links
  4. nabby68
    nabby68
    30 Jun 2005
    653
    Thanks Received:
    Country:
    Hi opps
    Much appreciated for your reply. The paint you suggest sounds good but maybe a bit expensive at £40 for 5l as the area I need to cover is quite large. Do you know of any cheaper alternatives?
    Thanks again
  5. opps
    opps
    16 Jun 2006
    5,166
    Thanks Received:
    817
    London
    Country:
    Look at the Leyland Hardwearing Matt.
    From memory is about 25%-30% cheaper. I don't think you will get a decent durable matt for much less though.
    The usual suspects- Crown, Johnstones, F&B, etc will all have their own variants. I don't imagine that they will be cheaper than Leyland. Not sure where you live, but here in west London, I am don't even know if any of my suppliers sell it (that said I have never asked).
    Another alternative would be to use a clear matt (waterbased) varnish over the matt paint (eg Ployvine) but that is more expensive and you need to vacuum the walls to remove all of the fluff/dust otherwise you will see it trapped in the clear varnish. Additionally, the clear matt varnish can make some paints become darker.
    • Thanks Thanks x 1
  6. Sponsored Links
  7. Yeahaa
    Yeahaa
    24 Nov 2018
    66
    Thanks Received:
    4
    Country:
    I really like Valspar paint , is expensive goes twice as far .
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
