Which render?
22 Dec 2020
Evening All
Having the front of the house rendered. I don't know the proper name for this silicone stuff.
We originally wanted a scraped k-rend (just due to a colour we liked). Had a number of quotes now but everyone has recommended different brands and also been told to use thin coat, not scraped texture.
I am basically asking is there some brands to avoid or even a golden product that I should be using?
Also worried about the waves (not totally smooth surface) is spraying a way to avoid this?
Thanks in advance
Every plasterer has different preferences.
And everyone will give different opinions.
what type of house is it?
Thanks. We put it down to preferences but just wanted to check if there is anything to know about from people that don't have a vested interest.
Detached. Brick built. Done some recent renovations and moved windows so decided to block the old openings up and have it rendered. The brick isn't a particularly nice one hence why we aren't bothered about it.
Have you decided what you are going for?
I am looking at rendering aswell....
Options are Silicon or Monocouche - with Monocouche being the cheaper option. I have been quoted £50m2 for Monocouche (including a sealant being applied after the Render has been applied). Apparently the Silicon lasts longer but Monocouche (at 25 years) is still good enough! Plus it can be easily painted over.
Hi, I am told monocouche is much more prone to cracking (not sure how true) so although I prefer the finish I think we are steering clear of that and going silicone. I am hoping silicone is much more maintenance free aswell. It is a minefield to be honest with all the options
Hi, I'm interested in what you finally decided on for the render.
I'm about to have an extension rendered and am considering ECOREND SR15 (that is silicone).
Whilst it's more expensive for the tub of ready mixed than the monocouche, the job appears to work out less expensive as the tub does approximately 10m2 where as the 25KG monocouche at 10mm thick just does 1.7m2. For 90m2 I'm told I only need 9 - 10 tubs but for the monocouche about 55 bags of 25KG. Do you know if there is some additional cost involved as it appears to be less labour intensive to me.
