Hi all, I've built a garden retaining wall (quite proud of the result too, being a novice!) and am now going to place a patio between the house and the bottom of the wall. The patio will 'fall' away from the house so I'll have channel drainage running along the base of the wall.
My question is should I lay the patio first then the channel drain, or set the drain first then the patio? With the patio running the width of the house and 5m across, I worry about the two meeting at the right height - especially with the drain needing to fall to each end!
Thanks for any advice
