Which type of valve to use?
25 Nov 2025
I've just picked up one of these things to provide a means of isolating the 22mm supply coming down from my large cold water tank into the bottom of my hot water cylinder:
Don't get me wrong, it seems great, but hell, I'm not shutting off the main water supply to a nuclear reactor! Should I be using something else for this job, it seems like an absolute monster for what I (in my novice opinion) feel like is a fairly trivial task.
I guess a wider question I also have is what type of valve do I use where; are there any rules I should be following?
That's the one for the job, full bore lever, which is especially good in place of gate valves on cold water feeds from loft cisterns.
Well there you go. Thanks for the info! I'll stick to that type then, where I can. 15mm version will be good for mains as well, I guess?
You could use a Gate valve, but they are prone to snapping from overuse or age.
