Which van to hire for large exterior doors?
6 Jun 2016
Need to collect some doors I have bought off ebay and transport them 100 miles or so, hence needing to hire a van. The doors have a frame size of W 168cm X 204cm, here is a pic:
I dont know whether they will fit in the 'medium' commercial van, or whether I should go with the 'large' commercial van? They are quite wide at 168cm so I dont think either van is wide enough to lie them flat, so may have to be tilted and leaned sideways against the side of the van.
Any thoughts?
Medium Van Commercial
MODIFY
Vauxhall Vivaro 5.9m³~ or similar
Large Van Commercial
MODIFY
Renault Master 11.3m³~ or similar
Thanks for the replies.
I got the dimensions off them, out of the large and extra large van there is not much in it other than length.
So I booked the large van, they cant specify which exact ione, length 3.73, height 2.14, width 1.77.
I think it will be ok if it goes in sideways and tilted to lean on side of van.
May be a bit late with this but if you haven't picked up the hire van yet then consider hiring a glazers type van with the outside racking.
