Been getting the above fault code with this dishwasher on and off for about 9 months. ( It usually clears if I run another program. ) The Quick Reference Guide says check inlet hose is not kinked and inlet filter is clean - both are OK. Other forums I've looked at have mentioned the inlet solenoid valve which looks straightforward enough to replace, but I've also seen mention of the "flow meter".
When I look up spares websites for this, they show a small elongated PCB, but the ADG 7800/2 manual's "exploded view " diagram shows the flow meter as being a small transparent vessel.
I don't want to launch off replacing the solenoid only to find it's the flow meter that's faulty.
Has anyone had any experience of this problem and in particular what does "changing the flow meter" entail in this case ? Is the flow meter the vessel, or PCB, or both ?
Thanks in advance.
Thanks in advance.
