Its 20 years since i touched a white knight gas TD, not sure if anyone on here has any more experience than me. so please bare with me as it has been a long time.
There are multiple bi metal thermal switches on these,. some are temperature control and some are overheat control..
They should all be closed circuit in their cold state going open circuit when they sense their cut out temperature.
The posssible components that would cause this are
Thermostat (Thermal switch) (there is a 60 Deg C, a 110 DegC and a 120 Deg C thermal switch)
HiSpeed control unit (This is an expensive part)
If it were the normal temperature control unit you would expect the appliance to overheat and then the thermal overheat switch would operate shutting the gas off which doesn't seem to be the case unless you noticed and didn't allow it to run long enough to overheat.
Firstly you need to be gas safe registered to work on one of these and you need the specific certification for this appliance which most engineers probably wont have.
These are not very common.
My approach would be to remove the switch place it on a metal plate above a gas burner, monitor the surface temperature of the plate and test for the switch going open circuit when the plate gets warm enough with a multimeter. (These switches are around £20 each)
If it did that then I would suspect the hi speed control unit which is approximately £280
Hope that helps
