whole house pump delay in water arriving when taps opened
8 Jan 2005
hi i recently had to drain down the cold supply to this pump to replace a leaking push fitting.
on re-filling there is something like 5 seconds delay before the water arrived under pressure while before it was instant.
im assuming its an air lock but if so how can i clear it.
also there's a non return valve on the cold feed from the pump, would that have anything to do with it?
the hot is working fine its just the cold which has the problem
any ideas appreciated
thanks
binguk, what is the pump description, model and serial number? is it flow switch or pressure switch operated?
do you get a flow imediatly when opening the tap or is the flow delayed?
non return valves in my oppinion are used to cover issues rather than cure and do caues a restiction so I would remove.
I would guess its either a flow switch issue with pump or not enough flow to activate the flow switch.
hi pumpman
thanks for the response
its a wickes 3 bar pump (not 5) but i cant seem to find it on the wickes site although this one is similar
http://www.wickes.co.uk/invt/160404/?source=123_75#mm_description
at present the hot is instant but cold is delayed since being drained and refilled
the non return valve was fitted because water roll back was activating the pump intermittently when taps were turned off
it runs the taps on 2 bathrooms and one shower
im working away at present so cant give you the serial
thanks
OK if your able to remove the non return valve as they cause a restriction. remember its teh gravity flow of water that starts the pump so if the gravity is delayed the pump will be delayed.
Most commonly people think the water is delayed coz the pump has not started/delayed starting. (This is a commonly mistaken view).
Get serial number/part number to clarify or picture may also assist. Wicks will have a branded item made by another pump manufacturer I would guess.
