- Joined
- 15 Nov 2023
- Messages
- 19
- Reaction score
- 0
- Country
this was my initial designIf it was me it would be 1 x RFC , and 2 x 6mm cables for the oven and hob
So ether way is within regs? (Just checking: are you certified electrician?) thanksWhy rings? Perhaps one ring or two radials.
I prefer the oven and hob on the same circuit and would also have the hood.
It is down to personal coice really.
Either way what?So ether way is within regs?
Registered - I was until I retired.(Just checking: are you certified electrician?) thanks
Hob and oven can go on the same 32A circuit.please advice and comment on the attached wiring diagram for a kitchen.
Wither way : one ring or two radials , both ways will comply with regs?Either way what?
Are you certified electrician ? Thanks. Seems like majority is for separating hob and oven though . At least from my "current" knowledge . Checking similar forums elsewhere and asked my previous certified electrician. I would probably put 20a mcb on oven circuitHob and oven can go on the same 32A circuit.
2x 32A rings is pointless, either have 1x 32A ring or multiple radials if you want things on separate circuits.
What do you think is a "certified electrician"? That's really not a UK term. If you want help from a known "certified electrician" best employ one.Are you certified electrician ? Thanks. Seems like majority is for separating hob and oven though . At least from my "current" knowledge . Checking similar forums elsewhere and asked my previous certified electrician. I would probably put 20a mcb on oven circuit
gosh you are sensitive, mate, I can see you've managed to understand the term. No offence, I am gathering opinions from every enthusiast and professional, but would give a bit more weight to pro's opinions. However even pro's are contradicting each other quite often. As for the term I guess more British would be to call it Lord of The SparksWhat do you think is a "certified electrician"? That's really not a UK term. If you want help from a known "certified electrician" best employ one.
Wither way
Of course, why wouldn't it?: one ring or two radials , both ways will comply with regs?
