Why can't you add a triple socket as a spur?
12 Jan 2006
Evening Everyone
Why is it the case with the above, as it says in several do it yourself books?
With triple sockets having a built in 13 amp fuse I would have thought this would limit the current drawn long before a 2.5mm spur would get get overloaded?
I havent read what you have read but I suspect that the book will be talking about three sockets without a protecting fuse. Not the three socket fused strips.
The reason is that a single piece of 2.5mm can carry 27amps maximum (I'm going from memory here) so two 13A sockets is on the limit. A third socket (at max load conditions) could take the total to nearly 40A = meltdown.
Thanks.
But I have just looked again and as for adding sockets it says:
"A spur can feed either one single or double socket. You cannot add a triple socket as a spur"
But yet it mentions "triple sockets have an integral 13 amp fuse to protect from overloading".
Just doesn't seem to make much sense really?
Nothing wrong with a fused tripple socket, is it no worse than plugging a 4 gang extension lead into a single socket.
I teach the regulations day-in, day-out.
I also read practically every technical book that appears on the market... usually armed with a red pen, in order to be fore-armed when delegates start questions with, "Well, this book says...."
The number of errors that appear is enormous - even in books by respectable authors with a large back catalogue. There is time presuure to rush books into print, especially those dealing with new regulations, so proof-reading is rarely thorough. (Even in the case of one particular well-known author, who actually gives a generous credit to his proof reader!)
A socket plate with its own fuse is limiting the current drawn in exactly the same way as a fused connection unit and is perfectly acceptable.
(By the way, why install rings at all? You'll only confuse electricians!)
Here here, down with rings.
I always extend a ring through the new socket anyway, so if someone was after a triple they'd normally end up with a couple of doubles.
Triple sockets - devil's work!
If there is a 13A fuse within the unit to control the maximum load, this is no different from a fused spur from a final ring circuit, where the thermal load maximum is say, controlled by a 13A fuse.
Regards
HI everyone, thanks for your advice.
So what is this learned "it" that you are quoting from?
It is from a "Wiring and Lighting" 'Creative Do It Yourself' series published 1994 (ward lock).
So if I needed to then would it be ok to add a triple socket as a spur? (say in a bedroom or sitting room)
Regards
Yes, there is nothing wrong with adding a tripple socket with a fuse in it as a spur.
