I recently bought 12 15ft lengths of regularized 4x2 timber.
some will be used to build a new stud wall and some will be used to baton a ceiling, it has a curve at one end so I am going to baton it with 4x2 and then plasterboard and skim the ceiling. I picked the 4x2 for a reason, because that thickness of timber would bring the level of the plasterboard below the unsightly curve.
I cut the timber to length, fixed it to the ceiling joists and checked with an off cut of plasterboard to see if the plasterboard would cover the curve in the ceiling, only to find that the timber wasn't thick enough. 4x2 timber would have been enough but the timber I had wasn't 4x2, it was about half an inch short on both sides. I have built quite a lot of stud walls with the same timber bought from the same place and have never had a problem. I also never noticed that 4 inch by 2 inch timber is no longer 4x2.
I was told that if you needed timber to be an exact size then you have to ask for regularized timber. I asked for regularized 4x2 and what I got was not 4x2.
how long has this been going on for?
