    Dismiss Notice
Why is the water not gushing?
Discussion in 'Plumbing and Central Heating' started by WD40solvesall, 11 Sep 2019.
  1. WD40solvesall
    WD40solvesall
    11 Dec 2014
    27
    Thanks Received:
    Middlesbrough
    Country:
    Hi all,
    I noticed this last night and I'm not sure if it's getting worse. Basically all the hot taps in the house are not giving out water with much force - if you have them on half turn it's almost a trickle, on full blast it's almost normal. I thought it might be my baxi boiler (usually is!) but it effected the shower this morning. The cold taps might be effected too, but if so not as obviously.
    Basically, I'm pretty sure i can fix it, but I don't know where to begin to find out what the fault actually is.
    Cheers.
  2. dilalio
    dilalio
    20 Mar 2009
    5,855
    Thanks Received:
    757
    Potters Bar
    Country:
    Firstly, you need to determine if it is both hot and cold supplies.
    Secondly, you need to inform us how your HW is supplied... Combi boiler/unvented cylinder/vented cylinder?
  3. WD40solvesall
    WD40solvesall
    11 Dec 2014
    27
    Thanks Received:
    Middlesbrough
    Country:
    I've had another look and cold water is also effected, but not as badly. I have a combi boiler, but the shower doesn't go through that so I think it's something before the water gets to either, would you agree?
    Don't know if it makes much different but I've done a lot of washing over the last few days, about 4 loads a day (not usual, just bedding and pillows). I don't know if this will have aggravated a as yet undiscovered problem.
  4. JohnD
    JohnD
    15 Nov 2005
    58,449
    Thanks Received:
    2,992
    21st Century
    Country:
    Cook Islands
    Might be a leak.
    Have you got a water meter?
    Do you know a young person with sharp hearing?
    How old is the house?
  5. Motman
    Motman
    27 Feb 2017
    3,205
    Thanks Received:
    370
    Essexshire
    Country:
    Do your neighbours have the same problem? Might be a general supply problem.
  6. WD40solvesall
    WD40solvesall
    11 Dec 2014
    27
    Thanks Received:
    Middlesbrough
    Country:
    Re: "might be a leak" - oh ......expletive! I really hope not. I'm not sure where to start looking! Plus the fool who owned this house before us just loved to box over every pipe and decorate it!
    No water meter thank goodness, house is 1930s build.
  7. WD40solvesall
    WD40solvesall
    11 Dec 2014
    27
    Thanks Received:
    Middlesbrough
    Country:
    Just checked - alas no :(
    How do you trace where your pipes go? One set of pipes we have seem to go nowhere as I think it got modified in the past. Hard to check without ripping the back out of the kitchen cupboards.
  8. JohnD
    JohnD
    15 Nov 2005
    58,449
    Thanks Received:
    2,992
    21st Century
    Country:
    Cook Islands
    How about a middle-aged person with average hearing? You need (at least) one assistant.
  9. WD40solvesall
    WD40solvesall
    11 Dec 2014
    27
    Thanks Received:
    Middlesbrough
    Country:
    FIXED!
    Thank heavens.
    The garden tap was attached to a hose with a sprayer, so hadn't been turned off, but looked like it. The hose pipe had split and was cascading water into the garden - because it's been torrential rain here we never noticed the difference!
    So, I'm slightly embarrassed, but hugely relieved. If only all DIY problems were so easy to solve.
    Thanks for all the advice everyone.
    • Like Like x 4
  10. Motman
    Motman
    27 Feb 2017
    3,205
    Thanks Received:
    370
    Essexshire
    Country:
    • Like Like x 2
  11. dilalio
    dilalio
    20 Mar 2009
    5,855
    Thanks Received:
    757
    Potters Bar
    Country:
    I wish my callouts were all that simple... And, if you WERE on a meter, I'd guess you'd be cursing the loss... I have customers on meters who think that a dripping tap into a basin is worthy of a 10pm Sunday phone call as it constitutes an "emergency" :cautious:
    Glad you sussed it and thanks for letting us know... Shows how simple it can sometimes be (y)
    • Like Like x 2
Loading...
Share This Page
