Why is there a puddle on top shelf under sink ?
13 Apr 2011
Antrim
Why does a puddle keep appearing on the top shelf under kitchen sink yet all pipes and anything that tightens or looses are bone dry?
Turn the taps on very slightly and you'll probably see water running back from the spout down the tap body then sneaking under the tap into the cabinet.
Where do i find that exactly?
The tap sits onto the sink, directly between the two and sink should be an anti rotation washer, inside the unit there should be a tophat washer or just a backnut, try running the tap slowly as above and try pouring/splashing some water where the tap sits and then check underneath
