If you go to a decent builders merchants, you should be able to buy 10mm limestone in 25 kg bags, also grit sand in the same size, plus a bag of cement. you can then make your own, which will be much better for your job. Don't forget the feb mix.
thank you for the help.If you go to a decent builders merchants, you should be able to buy 10mm limestone in 25 kg bags, also grit sand in the same size, plus a bag of cement. you can then make your own, which will be much better for your job. Don't forget the feb mix.
thank you. i will definitely look into it. workable is definitely what i needWell, it certainly makes it more workable.
thank you for the replyIt's always better to mix your own blend for 'fine' work. In your case you need builders sand, 10mm gravel (pea gravel) and cement. Mixing ratio of 1 measure Cement, 2 measures of Sand & 3 measures of Gravel. Febmix makes the mix more workable - a benefit when working with moulds. Add water slowly to make the mix workable. If you can work out a means of vibrating the mould as you fill so much to the good.
thank you.Thinking all the way back to my earlyish years, the ideal concrete mix for general building usage was to the ratio 3/4" 4-2-1 OP 2"slump; where the 4parts was the 3/4"agregate (downgraded), the 2 was the fines (blended sand) and the Op was ordinary Portland cement mixed with water to give a 2" slump when tested before pouring. That mix was SO popular, it was used as the 'control mix' by the then Ready Mixed Concrete company.
For container making, I'd opt for 3/8" 4-2-1 OP and less slump at say around 1" to 1&1/2" well rammed home and then vibrated to ensure zero air bubbles. .![]()
You are making some planters not building a reinforced multi storey car park (last time I performed a slump test) , forget plasticiser unless you are going to start laying bricks , just careful methodical tamping of a well mixed workable but not to sloppy batch as you fill the mould using a steel/wood rod will give you the desired result, if not, then go for some plasticiser and a vibrating poker and a slump cone and take cube samples to send off for compression testing and don't forget to make sure the air temp is above 4 degrees and not dropping otherwise you are into heating and mould protectionthank you.
i did read about slump during my research. i haven't got a cone (calling it that because i forgot what it's called) but maybe i will invest in one if i am going to be building more of these. i do plan to build probably 10 of them, maybe more.
thanks for the help
In addition to all the other chemicals in there?i don't want to risk putting unknown chemicals in there
i do have a small amount left so i will probably use that with some added sand just to use it up.
You don't need a slump cone for heaven's sake!! Just make the concrete as stiff as you can sensibly use it because that will give you the best finished concrete. No Clerk of Works is going to come along and condemn your mix as being out of spec!
I wouldn't bother with a` plasticiser either and just to clarify Air Entraining is commobly specified for roadside or marine concrete structure where the micro bubbles are intended to act as crack arresters within the matrix, Yes there is workability benefit but the strength potentially REDUCES zs 5% (typically) isn't concrete so the admix is combined with a plasticiser to enable the water-cement ratio to be reduced to Increase the strength.
thank you both. it did feel like i was starting to over think things haha i will keep it simple. thanksYou are making some planters not building a reinforced multi storey car park (last time I performed a slump test) , forget plasticiser unless you are going to start laying bricks , just careful methodical tamping of a well mixed workable but not to sloppy batch as you fill the mould using a steel/wood rod will give you the desired result, if not, then go for some plasticiser and a vibrating poker and a slump cone and take cube samples to send off for compression testing and don't forget to make sure the air temp is above 4 degrees and not dropping otherwise you are into heating and mould protection
