why
11 Jun 2005
Cambridgeshire
hi im full of questions this morning :) why is it that when my sis in laws water only is on via gas boiler does her rad in bathroom ( next to boiler ) gets hot i obviously have turned it off :D thanks
cos its what is know as a bypass rad, it helps reduce the heat within the return to the boiler when system is in hot water only mode
its out dated now and modern part l compliant systems incorperate an automatic bypass for this purpose
It may be part of the design, not necessarily just there as a bypass. SOmetimes called a "summer loop". Buy if you reckon you've turned it off, then it should be - OFF!
Summer loop is a bypass mate
if its acting as a bypass should it not be on? (we have similar and our is left on)
And not only that if it was acting as a by-pass then it shouldnt have valves fitted.
bloody regs :lol: :lol: :lol: :lol:
not even lockshield valves ?
how would you connect the rad then DIA :?:
Straight or bent MI x CU compression fittings in the same finish as the radiator e.g. chrome, nickle
