- Joined
- 31 Aug 2013
- Messages
- 261
- Reaction score
- 1
- Country
Tightened it as far as it will go. Something's not right chaps
You've crossed the thread on the nut.
Not to mention the flirking big king in the flexi.
You will probably be able to undo it, carefully persuade it to thread on straight and be ok doing it back up...Thanks chaps.
I'll report back with the results
Daniel
If that was a dig at me, it doesn't always work that way.Its easy to remake the threads!!!!
ha ha "tap n die set" "buy a new one" (strange folk)
Simply run the check nut (the one holding the inlet valve into the cistern) back down the threads and off, it will redo the correct threads then start again.
