Will 15mm do...?
22 Feb 2008
Northumberland
Thanks to a dripping manifold which has spurred me into action, I am finally getting around to replacing my 8mm microbore with some decent sized copper pipe. The manifold is fed by 22mm both flow and return and I was planning on teeing into the flow with more 22mm up the hall towards the radiators (about 3m away) before reducing to 15mm. Will I need to return the same distance with 22mm or will 15mm back to the 22mm be ok?
3m won't make a lot of difference!
15mm pipe will supply about 4kW from a non condensing (ie older ) boiler.
Thanks Chris,
The boiler is a Baxi 105, does that make any difference?
I was just concerned about restricting the flow of water back to the boiler, or does it not make that much difference?
