Will this adhesive be ok around my wood burner?
25 Jun 2020
I tiled around my fireplace last night with Weber fix plus tile adhesive which withstands up to 100C...I thought that would be ok for what I need it for as I'm not tiling underneath or in the actual alcove that my wood burner will sit in. However, after doing more research AFTER tiling (doh), I'm now starting to worry this won't be any use. Any thoughts? It takes 24 hours to dry fully so if I need to take them off, I'd rather do it today before i fully sets, rather than later. I'm thinking I might only need to redo the ones along the top as they'll be directly above the heat?
if that gets anywhere near 100c you need to leave the building.
Well this is what I think! I've gone with it. Thank you
