- Joined
- 25 Oct 2010
- Messages
- 20
- Reaction score
- 0
- Country
It's a long story but we have a loft conversion, finished but not passed by building regs as they require a fan 15L/s with 15min over-run.
Rather than cause loads more disruption we've decided the easiest route is through a velux window...any advice please on....
i) The best type of fan
ii) wether it's best to fix the window shut?
On i)
There is a good smallish and slimline MANROSE, but not sure if the window pane would have to be single glazed (up to 10mm) it says in the cataloque...could a thinner pane than the 24mm be fitted securely without leaks etc..
There is slightly bigger Nuaire product apparently suitable for double glazing (32mm)...?
on ii) the opening will probably be restricted to stop wires being caught.
Incidentally has anyone heard of velux developing an automatically opening window with a humidity sensor...I've emailed them to ask...because they already do a similar thing for rain (closing) and smoke (opening)?
Thanks,
John H.
On i)
Thanks,
John H.
