Window Opening question
12 May 2016
Require some advice please
Mid terraced property customer wants to split the front master bedroom in to two creating smaller bedroom and a bathroom (moving it from the back to the front of the property).
For the bathroom a new small window opening is required
is that a planning application or building regs only
thanks in advance
Not a small one
Mid terraced house. 2 windows on each floor master bedroom first floor and front room on ground floor. Also a front door entrance
Standard terraced house windowns 6 x 3ft
I don't know where everybody's got to today. Well, as long as the property isn't listed/in a conservation area/subject to any article 4 exclusions, and permitted development rights are intact, then you should not need to apply for planning permission for insertion of new windows of a similar appearance to those already there - but I'd get the view of the duty planning officer just to be sure.
Apply to get a lawful development certificate (LDC) to protect your backside.
Inserting a new window in a front elevation is permitted development, pure and simple. (unless a listed building etc).
(No point in asking the planning department - by default they will just say it does need p.p. to get the fee in)
tony1851 My only concern is that requirement to match existing windows. Presumably, it means in terms of style and materials only?
Yes, it's a common misconception that new windows need planning permission, even among planning officers, who should know better.
Look in Class A of the GPDO, and there is no prohibition on new windows to any elevation. As this is not expressly prohibited, it is permitted.
Yes, it simply says that materials must be of a similar appearance to those used in the construction of the exterior - appropriately vague.
