Window sealant with wallpaper
27 Sep 2010
Nottinghamshire
Hello,
I'm planning on wallpapering a room, however the windows need the sealant tidying up. This has given me two questions that I'd like answering if anyone could please help:
1) Do I want acrylic or silicone sealant? Various places say acrylic when painting, but obviously I'm not doing this. Silicone seems better due to it being waterproof, but I thought I'd ask just to be sure.
2) Due to the sealant being there if I put the paper into the corner (for cutting) the corner is actually the middle of the sealant joint. Should I be leaving the paper overlapping onto the sealant slightly or try to cut it right up to the edge of where the sealant falls?
Silicon sealant should not be used inside around windows really. I'd cut it out and then re paper. Then maybe run some caulk along the edge of the paper that touches the window.
Silicone is the window fitters friend. You have to hold a FENSA certificate to silicone round a windowo_O
