Heights of opening windows, which part of the Building Regulations is applicable?
Thanks.
Thanks.
Aye, this needs to be 1100mm to comply. Inspectors rarely budge on this IMO. http://www.planningportal.gov.uk/Pp...portal.gov.uk/uploads/br/BR_PDF_ADB1_2006.pdf section 2.8 page 19 of the document not the pdf.1215mm to bottom of opening window
I'm a little confused... you're arguing with the BCO who has refused to issue a completion certificate because the height to the bottom of the openable window is 1215mm and the regulations state this has to be a max. of 1100mm?
You contravene the reg's so of course he wouldn't issue you with a certificate...
Pay attention DD!I'm drafting a letter to a builder and wanted to state the relevant parts of the building regulations which is contravenes.
Ahhh my apologies
In that case, I'm not sure where you'd stand with the builder as they wouldn't know the full in's and out's of the building regulations.
That's not acceptable.
Considering that the Building Regulations are statutory then a builder should carry out work to comply. There can't be any argument or excuse against that.
Unfortunately the responsibility falls to the client or designer/architect unless the builder has specifically been appointed to achieve a Building Regulations compliant standard ie its written into their contract. To assume a builder will know the Building Regs inside out is naive at best however unreasonable you think that may be. It is not a given on every job at all. Is the builder working to a set of working drawings and / or specification?
Yes, the builder worked to a specification which stated the opening of the window to be between 800mm and 1100mm above finished floor level
