The windows installed in my extension are cold bridging over the Thermobate insulated closers and must be moved according to my bco.
How can i fix these properly as the windows are fixed through the middle of the 70mm frame and bco says to sit the frame into the cavity by 30mm which means there is no brick to fix into.
This is the first time i,ve encountered this problem, anyone find this problem and solution elsewhere???
