The machine is standalone, I don't use roaming profile etc. Not sure what server it is trying to connect?
If I click the link it brings up the windows help file:
[code:1]
Details
Product: Windows Operating System
Source: DCOM
Version: 5.0
Component: System Event Log
Symbolic Name: EVENT_RPCSS_SERVER_START_TIMEOUT
Message: The server %1 did not register with DCOM within the required timeout.
Explanation
The Component Object Model (COM) infrastructure tried to start the named server; however, the server did not reply within the required timeout period. There might be a deadlock, or the program might not have responded to the server initialization code within the timeout period of two minutes.
User Action
If the problem continues to occur, contact the program vendor.
To determine the program vendor
Using Regedit, navigate to the following registry value
HKCR\Clsid\clsid value\localserver32
The clsid value is the information displayed in the message.
In the right pane, double-click Default. The Edit String dialog box is displayed. Leave this dialog box open.
Click Start, and then click My Computer.
Using the information displayed in the Value data box of the Edit String dialog box, navigate to the program.
Right-click the program name, and then click Properties.
The Properties dialog box for the program is displayed.
To determine who the vendor is for this program, refer to the Version tab.
Version: 5.2
Explanation
User Action
[/code:1]
Might have a play about later tonight.
Cheers
Just fired up the PC again and the event viewer is showing Kservice not started which I believe to be something to do with the BBC player. I have just uninstalled it to see if it makes a difference.
Everything appears back to normal now,
Spark123
