- Joined
- 21 Oct 2026
- Messages
- 3
- Reaction score
- 3
- Country
Depends where it is:
If you're getting black mould round the frames, it's the same story: clean it off, then sort the ventilation or it'll be back. If it's one patch on the reveal, it might be a cold spot round the frame, so get the fitter back to look.
- Outside: nothing wrong. The glass is doing its job and keeping the heat in, so the outside pane is cold enough for dew. It goes when the sun's on it.
- Inside: that's moisture from the house (showers, cooking, washing, breathing). New windows seal the draughts that used to let it out, so you notice it more. Open the trickle vents and leave them open, use the extractor fans, and try not to dry washing on the radiators. Wipe it down in the morning.
- Between the panes, where you can't wipe it off either side: the seal on that unit's gone. Usually just the glass unit needs replacing, not the window. Check your guarantee if they're not old.
