Wireless door chime fail
24 Aug 2009
Nottinghamshire
I bought a siemens wireless door chime, tested it, worked ok, fitted it and noticed it was at best intermittent.
Took it back to BnQ and it worked flawlessly
Bought it back here, wont work flawlessly
I guess something is interfering as my car remote is shorter range at home too
Tried turning off all flourescent (energy saver) lights
Turned off my wifi (i have 2.4 and 5 GHz)
Turned off digisender
I'm at a loss now. Maybe one of my neighbours is a pirate radio station?
Any ideas anyone? I cant find the manual for the alarm :(
4 Jan 2004
They normally give you half a dozen bands to avoid interference have you tried the other bands.
They need to match both on the main box and the sender (bell push).
Suprised B&Q didn't tell you this.
1 Mar 2009
Blackpool
Is the button mounted on PVCU door frame? At the bottom of instructions it usually warns you not to mount on pvcu. You only find this when you have opened packaging.
A
Alarm
Foil backed plasterboard?
Other items on the same frequency?
Are there any dip switches there? Try changing them ( both the same of course).
24 Aug 2009
Nottinghamshire
Hmm, it was mounted near the lock (over hole if old wired one), moving it down below that seems to have worked
Very poor range.
And no, its a wooden door
22 Jan 2012
Jersey
I have the same doorbell, purchased from B&Q. The button and receiver are about 2 meters apart, and the button covers the position of the old wired doorbell.
Mine is working fine, through a 2 block wall with insulation between. My wireless (2.4GHz) router is also very close by.
Strange that moving your bell down a bit resolved it!
You probably know but if you turn the receiver off, within a minute or 2 of turning it back on you must press the doorbell button, or it won't work at all!
