    Dismiss Notice
wireless printer
Discussion in 'Software' started by pennycressl, 21 Sep 2012.
  1. pennycressl
    pennycressl
    11 Mar 2010
    26
    Thanks Received:
    Wiltshire
    Country:
    good morning
    virgin media have changed my router
    and i am unable to get my HP DESKJET 3050 printer
    to go wireless it was perfect before the new addition
    it will print via cable
  2. Sponsored Links
  3. kjacko
    kjacko
    17 Dec 2008
    1,138
    Thanks Received:
    41
    Nottingham
    Country:
    You need to reassign an IP address to your wifi printer that's within the scope of the new router as it 'may' have changed. Almost certainly the SSID would have changed.
    Easiest way is to use the one button wifi setup. Press it on your router, it's either by physical button or a button click on the web admin page, then press the button on your printer. This should set up the new IP connection for you.
    hope that makes sense.
    • Thanks Thanks x 1
  4. pennycressl
    pennycressl
    11 Mar 2010
    26
    Thanks Received:
    Wiltshire
    Country:
    Thanks but not sure about the button. Is this the one marked reset on the router?
  5. ^woody^
    ^woody^
    3 Sep 2006
    32,761
    Thanks Received:
    4,428
    West Mids
    Country:
    Go into the router admin page and you should see the printer as a wireless device. The router should be assigning IP addresses automatically
    • Thanks Thanks x 1
  6. Sponsored Links
  7. kjacko
    kjacko
    17 Dec 2008
    1,138
    Thanks Received:
    41
    Nottingham
    Country:
    It won't if he doesn't manually try and connect to the new SSID. And that will likely have changed with the new router install.
    • Thanks Thanks x 1
  8. kjacko
    kjacko
    17 Dec 2008
    1,138
    Thanks Received:
    41
    Nottingham
    Country:
    NOOOooooo......lol.
    Don't do that. THe button should be marked, possibly with "WPS".
    • Thanks Thanks x 1
  9. pennycressl
    pennycressl
    11 Mar 2010
    26
    Thanks Received:
    Wiltshire
    Country:
    still not sorted yet
    will try all suggestions later
  10. pennycressl
    pennycressl
    11 Mar 2010
    26
    Thanks Received:
    Wiltshire
    Country:
    Thanks for all your help we are now Wireless
Loading...
Share This Page
