There should be no delay. If it's cold and the thermostat is calling for heat the valve should open the moment the programmer is switched on.However since both the thermostats seem to have a delay I am not too sure about wireless now.
On a Linea?Vokera's own OpenTherm stat will give you the best heating efficiency
http://www.vokera.co.uk/trade-professionals/controls/
However since both the thermostats seem to have a delay I am not too sure about wireless now. Could strangle the central heating installers as there was already a wired thermostat when they replaced the boiler and they cut out all the wires.
I agree with what you say, it seems there is a regular command sent, some where I have a wave meter may be that will show how often it transmits, or maybe I can find the frequency and use my FT50R to monitor it. But other than that it is hard to know what is going on, and more to the point with this point, do all thermostats do the same?However since both the thermostats seem to have a delay I am not too sure about wireless now. Could strangle the central heating installers as there was already a wired thermostat when they replaced the boiler and they cut out all the wires.
Wireless on a licence exempt frequency is never the best option for communication when wired is an alternative.
The delay may be because the thermostat only transmits a status report at regular intervals and not immediately the demand is created. It makes sense that it sends regular status reports since a single transmission of the command "BOILER OFF" may be lost and then the boiler would continue to run even though the thermostat was no longer calling for heat.
Depends which Linea it is!On a Linea?Vokera's own OpenTherm stat will give you the best heating efficiency
http://www.vokera.co.uk/trade-professionals/controls/. Pretty sure OpenTherm compatibility wasn't included on them back then
Better that than freezing or sweating for several weekends if ( when ) the wireless link doesn't linkThanks, Ill be fishing and swearing this weekend........
A much better solution.I am beginning to think I may just run a bit of 3core+earth from my exiting programmer which is a cupboard to the hallway and fit a wired programmable stat
