Wireless Pyronix enforcer questions
12 Jul 2008
Wiltshire
Hello.
For a year or more I've wanted a wireless keypad for my alarm. I've spoke about it on here but before and called my installer who said my unit isn't compatible.
However I think it is. My version is 9.52 and map security state 9.5 or higher is required.
My questions..
1) If I buy the keypad myself can anyone supply me a step by step guide for programming it.
2) can I activate a strobe light in the bell box. If so any guide on this too?
Also, I do have the installer code.
Thank you for your help!
that is correct that the LED/WE will only work with later panels BUT I'm not sure of the cut off date....
On another note if you did not fit panel, then you should be aware that you will need the engineers code to access back end
of system.
Thx
Matt
I do have the engineers code. Not that it's any good to me as I don't know how to programme it and cant find an installer to do the job ‍:cry:
Programing isn't hard you should easily be able to do it yourself, it's just knowing if it will work or not.
